show snmpv3 engine-info
Description
Displays information about the SNMPv3 engine on the switch.
Syntax Description
Default
N/A.
Usage Guidelines
The following show engine-info output is displayed:
  • Engine-ID—Either the ID auto generated from MAC address of switch, or the ID manually configured.
  • Engine Boots—Number of times the agent has been rebooted.
  • Engine Time—Time since agent last rebooted, in centiseconds.
  • Max. Message Size—Maximum SNMP Message size supported by the Engine (8192).
The following command displays information about the SNMPv3 engine on the switch:
The following is sample output from this command:
SNMP Engine-ID          : 80:0:7:7c:3:0:30:48:41:ed:97 'H'
SNMP Engine Boots       : 1
SNMP Engine Time        : 866896
SNMP Max. Message Size  : 8192
Platform Availability
